Setting Purchase Preferences Temp
Jump to navigation
Jump to search
Prior to your first purchase, you will need to set up your account information and provide an email address. The email address is used by the music stores to notify you of your order information.
Also, if you plan on streaming music, you will need to set up your account to allow this. To understand the Preferences relating to streaming music, refer to Karaoke Cloud and TriceraSoft.
Please note that kJams keeps your credit card information encrypted at all times.
To set up your basic purchase account information:
- Go to Preferences, then click on "Stores". The Stores preference panel is displayed.
- Click on "Edit Credit Card Settings".
- Enter your credit card information.
- Note that your card #, expiration date, and security code are immediately encrypted (you can't see them), so be sure to enter them correctly.
- Click "OK".
- Click "Edit E-mail Address".
- Enter your email address. It’s important to use your real address because this is how you get your receipts.
- Click "OK".
- If you want true “one click” shopping with no questions asked, un-check the "Confirm All Purchases" box. This is not recommended for newbies, as it is very easy to purchase songs without realizing it.
- The menu "Include Store songs in “Library”:" allows you to choose which songs from the stores appear in your "Library" playlist. For example, if you pick "All Songs", then when you are searching your "Library" it will search not just your library but also all the music stores at once.
- If your are planning on streaming music, purchase your subscriptions and then set your preferences according to the information located here: Karaoke Cloud and TriceraSoft.
- Click on OK to exit the Stores preferences panel.
Daveanswer??Do we need to mention other Preferences here??? dave: nope
