CouldntGetRequiredComponent
Jump to navigation
Jump to search
if you're getting this error, first, make sure you're on the very latest kJams.
If you're still getting the error, do these steps:
- run kjams
- go to the Help menu, pick "reveal preferences"
- quit kJams
- delete the kjams app from your hard drive (delete ONLY the app itself, nothing else) empty the trash
- in the folder that was revealed by kJams, delete the folders "import" and "export", NOTHING ELSE
- download kjams again
- unzip it and drag it to your Applications folder, delete the zip file
- run kjams
- preferences->exporting
- make sure your codec and preset are correct, hit OK
- export like normal
If you do all this it should work.
