Artwork Panel Temp
The Artwork Panel shows the graphics for the song that is currently playing. It's handy when you (the KJ) are not able to see the lyrics on the screen. For example, the TV displaying the lyrics is in front of the singer on the stage, not in front of you.
To reveal the artwork panel, click the little tri-angley button to the right of the repeat button. To hide it, press the button again.
Eventually, you'll also be able to see the selected Singer's photo (and take a picture too), or use the panel to cue up the next song, showing a selected song rather than the current song.
Second Video Window
You can also show a second video window (see the Windows menu). This window operates just like the first one, except for these things:
- It cannot go transparent. (Let me know if you need this.)
- It does not respond to auto-show and hide preferences.
Other than that, it behaves exactly the same. The Video window sizing commands operate on the front-most video window.
For a rather awesome setup, you can use iDisplay and put your second Video window onto that screen, and then put that in front of the Singer.
