Meta Info
From KJams Wiki
Contents |
What is it
The info associated with songs, eg: unique song ID, track number, track title, artist, album, duration, times sung, key, etc etc. Much of the info is stored in the XML Meta Data Files that live next to the actual song file.
When Ripping
Before you rip, please set all your metadata on the CD *first*. Here are the instructions, and here is why it needs to be done first.
When "Add to Library…"-ing
If there is any, it will be scanned and you will be saved the trouble, else you must do a little work first. Instructions.
Pushing and Pulling
This is for older users of kJams, who started prior to 1.0d45r22. Newer users need not do anything special, as you should always remain in sync.
This refers to synchronizing the kJams Database of meta info with the individual song files. Under "Advanced->Special" you'll see these new entries. Push means, take whatever metadata you see in the browser, and update the tags in the actual files on disk. Older users only: If you've edited your meta info prior to r22, then you'll want to "push" your work into the song files. Or, if you just added to library and never edited info, you want to "pull", which will pull the tags out of the song files and update the kJams database, you'll recover artist and album info this way, if it's not already there.
Kinds
MP3 ID3v2.3, Vorbis Comments, QuickTime meta, and Xattr. These are all handled the same from the user interface, with the "Get Info" dialog.
Editing Disc Info
- Double click the CD (or select it and File->Get Info… (⌘-I)) and you will see this:
- If the album is a compilation of artists (typical) then in the "Artist" field, enter "Various", else enter the artist's name
- For "Album", enter the publisher abbreviation followed by the disc number, eg: "Sound Choice 4321" would be "Sc4321". This is the sortof standardized format for referring to a Karaoke album. If it's a regular CD you can just enter the actual album name
- Make sure you enter a year, zero is NOT a valid year. If you're not sure, just set it to this year.
- For Genre, you can type it in if you know it, or pick from the list. Best to pick from the list to make sure it is legal.
- For category, it frankly doesn't matter. Pick something, anything. "Misc" is fine.
- Press "OK"
Edit info for All Tracks
- Select all the tracks (select one, then go "Edit->Select All")
- File->Get Info… (⌘-I) and you will see this:
- If the Artist is the same for all tracks on the disc, then enter the Artist name (in this example, "U2"). Most karaoke discs have various artists on the disc, in that case, skip this step.
- The Album should already be set from the previous step
- If the Genre is the same for all tracks on the disc, then enter the Artist name (in this example, "U2"). Some karaoke discs have various Genres on the disc, in that case, skip this step.
- Set the year
- Hit "OK"
If there are a subset of songs that have the same artist, select only those songs, get info, and enter the artist, this sets the info for all the selected songs. Repeat as necessary for all groups of songs that have the same info, eg: genre.
Edit Info on Individual Tracks
- Select track # 1 only
- File->Get Info (⌘-I) and you will see this:
- Enter the song name
- If the artist is unique for this song, enter the artist name too
- Press the "Next" button (or ⌘-N or ⌘-➟) and repeat the process 'till you wrap back around to the first track. (⌘-P or ⌘-← will go to previous)
- Press "OK"
Now that you've entered the info for the disc, please submit it to the "freedb" so that others may benefit. Select your CD and go to Advanced->Submit CD Tracks to freedb
Meta Data and Offline Volumes
If you keep your music on an external hard drive, and you run kJams when that volume is offline, you run the risk of being confused, because you will NOT see any meta data that is not stored in the .ktd database file. FYI, the info that is always stored is:
Song Name Album Name Artist Name File References (the path to these files: audio, video, zip, meta (.xml) MediaStream, Launch File Genre Comment Year Size Tempo Pitch Date Last Sung Rating Times Sung Format (mp3, aac, vorbis etc) Missing Song ID Vocal Channel Graphic Channel Start Time Duration Track Number
That means that NO OTHER META DATA is stored locally, everything else is stored on your external hard drive. That means for example, if you use Label color to colorize your songs, your colors will seem to "revert" to "None" when you run with your drive offline. But don't worry, this is just an appearance, the next time you run kJams with your volume back online, your colors will come back.
When you edit meta data of songs who's volume is offline, the meta data that is not stored in the .ktd file is stored in the "Songs Meta.xml" file. The next time you run with your volume back online, kJams will push this meta data onto the external volume.
The only way you can LOSE data is if you start kJams with the volume ONline, and then it goes OFFline, and then you edit more meta data.
