Canceling iTunes Launch Temp
Jump to: navigation, search
Before you put in a CD, it’s a good idea to turn off the thing that automatically launches iTunes when you put in a disc. If iTunes launches automatically, your songs could end up in the iTunes library, which isn’t a good thing. You don’t want to do this!
To turn off iTunes on a Mac:
  1. Go to Apple → System Preferences → CDs and DVDs
  2. Change "When you insert a music CD" to "Ignore". Or change it to kJams. But make sure it does NOT run iTunes. If iTunes is running, exit out of it.
To turn off iTunes on a PC: davequestion: how do you do this on a PC?
