Finding double titles
lollebol
Post by lollebol »
Hallo,
At this point I have a very large database of almost 13 thousand songs with as few doubles as possible but so far I have to check them manually. That takes a lot of time each time I do the checking.
Would there be a way to have a function included that makes searching for double titles possible? It's only an idea but it would become easy than.
Kind regards,
Jerry. :wink:
Re: Finding double titles
Go to File/New Preset Playlist/Unique Songs
Note that will NOT work unless you have Perfect Metadata.
To learn how it works, see the article on Preset Playlists.
