VCD ripping is now available. note, must rip before playing,
eugalino
Post by eugalino »
https://karaoke.kjams.com/wiki/History
Does that mean Kjams can play VCD discs? Because if it does I can't figure out how to do it.
Re: VCD ripping is now available. note, must rip before play
No, kJams can not *PLAY* VCD discs. But it can RIP them. First, rip the disc (or just the songs you want). THEN play the songs from the disc, but you play them from the Library.
Be sure to set the meta data BEFORE you rip.
