Missing Music and Duplicates
CO&Play
Post by CO&Play »
Kjams -
Love the software - however I'm missing a lot of music specifically several Sugarland tunes which I should have.
I'm downloading from a hard drive - is there something I can do to retrieve this missing music??
Second question - I believe I have several duplicate songs (from attempting to retrieve music from problem #1) is there a way to delete the duplicates?
Thank you for your help.
CO&Play
Re: Missing Music and Duplicates
I'm missing a lot of music ... which I should have.
well without knowing what you did i have no idea. but i can say that songs go missing typically for one reason only: you moved the song file AFTER kJams added it to the library.
http://karaoke.kjams.com/wiki/Missing
i don't think "download" means what you think it means.
http://karaoke.kjams.com/wiki/Glossary
i think you mean "copy", right? :wink:
either rebuild your library from scratch, or put the files back where they were before you moved them, or use the "symlink" trick.
http://karaoke.kjams.com/wiki/Moving#Th ... Link_Trick
http://karaoke.kjams.com/wiki/Preset_Playlists
CO&Play
Post by CO&Play »
Dave -
Thank you so much for the input - and yes download was a poor choice of description.
I don't think I moved any files - and I'll definitely give symlink a try. If that doesn't work how do I "rebuild" my library.
Thank you again.
CO&Play
the symlink trick is only useful if you moved your files after you told kJams where they were. what you should do is confirm this first by looking at the "missing" article.
