DVI adaptor
gbrad
DVI adaptor
Post by gbrad »
I'm a newbie, I have a 13" Macbook. I would like advice on which dvi to video adaptor to use. I tried a Dynex model, but nothing but blue screen. Recommendations please.
Thanks.
Re: DVI adaptor
Presuming you have a Mini-DisplayPort, you need the mini-displayport to VGA adapter, then you need a scan converter to go to TV.
http://karaoke.kjams.com/wiki/FAQ#How_d ... on_a_TV.3F
Sedge
Re: DVI adaptor
Post by Sedge »
Yes, mini-displayPort to vga adapter, then a scan converter. For scan converter, I recommend the kworld PC to TV box. I use it, and haven't had any issues so far. Also, it's USB powered, so no need for additional room on the power strip.
I think it cost about $50 at Fry's.
- Sedge
gbrad
Re: DVI adaptor
Post by gbrad »
Thanks for the feedback. I did find an vga to video converter. Just got it today. Right out of the box, plug and play.
Re: DVI adaptor
