What kind of set-up do I need?
djdave
Post by djdave »
I'm a long time mac user(desk top) that does 3-5 shows a week with discs. I'm finally going to switch to a laptop since kjams appears to work great. What type of mac system would you recommend?
Thanks,
djdave
Re: What kind of set-up do I need?
the max computer your budget allows. macbook pro, 4GB RAM, try to get a "HL-DT-ST DVD-RW" drive for it (rare, ebay)
mdonofrio
Post by mdonofrio »
Sorry Dave, the standard DVD RW that come with MacBook or iMac is not right for reading Karaoke commercial disks?
the iMac probably WILL have a drive that works, the MacBook probably will NOT, however, YMMV, it's hit or miss.
djdave
Post by djdave »
Thanks Guys. Maybe an I-Mac with a nice case?
djdave
"nice case"? huh?
jfbiii
Post by jfbiii »
I seriously wouldn't want to cart an iMac around, but I guess you could. It's maybe a more attractive proposition if you are literally only going to be using it for shows. Or if you're a permanent install.
what is a "nice case"?
Jon Leggitt
Post by Jon Leggitt »
I'm guessing he means a case for transporting said iMac...
jfbiii
Post by jfbiii »
OICKTHXBAI
SWLinPHX
Post by SWLinPHX »
Anyone else have no problem ripping using a MB Pro 15" Unibody? Did I just get lucky? :?:
MacBook Pro-15.4" [unibody] 2.53GHz-4GB: Mac OS X 10.5.7
also:
iMac G5-20"/2 GHz-2 GB: Mac OS X 10.4.11
iBook G4-12"/1.33 GHz-1.5 GB: Mac OS X 10.4.11
PowerMac G4 w/21" CRT Studio Display/500 MHz-1 GB: Mac OS X 10.3.9
You got lucky.
SWLinPHX
Post by SWLinPHX »
Really? When I got the initial error message that it as reporting "not compatible" I selected "try anyway". My built-in DVR-R/RW drive on my MB Pro is the following. Is this what you guys show?
Model: HL-DT-ST DVDRW GS21N
Firmware Revision: SA15
Interconnect: ATAPI
Burn Support: Yes (Apple Shipping Drive)
Cache: 2048 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: Insert media and refresh to show available burn speed
s
also:
Yep, that's right, "HL-DT-ST" is one of the good ones. Lucky!
It does not report that it is capable, that's why kJams says "probably won't work", however it is in fact capable, that's why kJams let's you "try anyway", cuz some drives say they can't when they can!
Have you tried burning a disc?
