hello -
I'm using an iMac...and the Kjam Lite.
I've imported a song and the song plays but I can't see the words in the black screen. I can see the name come up but nothing else.
Not sure where to get the text in.
Video is black
Re: Video is black
Sounds to me like there are two possibilities. 1) You added a song that didn't have karaoke lyrics in the first place. Did you ever see this songfile play as a karaoke anywhere else? If you know it is a good karaoke, then:
2) If it was not already stored as a zip file when you added it to Kjams, you should have ripped it to add it to you Kjams library.
Re: Video is black
Thanks for the reply...I finely got it going. Not quite sure what I did. I played around with some of the video settings.
They were AIFF files...that worked on other setups...PC.
Please excuse me, but I'm a novice to this stuff. When it finely worked, I just put my disk in an it worked. (no importing or anything)
I would think that I would want to store these on the harddrive and not a disk.
When you say ripped...what do you mean?
Re: Video is black
Ripping is the process of storing to the hard drive. See this:
http://karaoke.kjams.com/wiki/Ripping
Re: Video is black
seems like you are all set now, let me know if you need anything else.
