Can't search for Singers
waynegfx
Post by waynegfx »
I go to the venue and try to search for a singer and it hangs up with this message.... Assert Fail: sql_col_sizeL, in file: '../../../../_source/Shared/CDB_Qt.cpp' at line 2494
Re: Can't search for Singers
noted. is rebuilding the sqlite from the .ktd file an option for you?
waynegfx
Post by waynegfx »
I have no idea what that even is.
see this link
after you rebuild, let me know if you still experience the problem, or if the problem is fixed
waynegfx
Post by waynegfx »
I rebuilt the song list and the same problem came up again. I absolutely love kJams and can't wait to use my new MacBook Pro M1 computer with it.
can you do a screen cap video of that? i'm not seeing the problem
is this problem still happening? can you do a screen capture vid?
i'm assuming this problem is fixed
