Pause not function.
dreben
Pause not function.
Post by dreben »
Hi Dave, Pause not function. What to do? Kjams2
Re: Pause not function.
sorry but what does "pause not function" mean?
do you mean "pause between tracks" isn't working?
what it is supposed to do is go to the next track, load it up, cue it to the start, and pause, so all you have to do is un-pause to start the song.
is that not what is happening?
dreben
Post by dreben »
Hi Dave, Please excuse my English. This is exactly what happened. There is no pause between tracks. I load several songs and they all start playing
one by one with no pause in between. As you can see the function is checked.
i'm not seeing this. please send me your prefs file:
https://karaoke.kjams.com/wiki/Send_Lib ... references
dreben
Post by dreben »
I've send you "kjams".zip file with preferences. I hope it will help you, solve the problem. Thanks.
update to latest and try again?
dreben
Post by dreben »
Hi Dave, I'm with the latest version - 2.1b42.
i'm still not seeing this. can you text me so we can set up a screen share? you can find my contact info here.
are you still seeing this? if not, i'm going to consider this bug fixed / closed.
dreben
Post by dreben »
No Dave, it's not. Steel having the same issue. And because there is a big time difference I'm not sure when can i call, or having chat. At this very time here in Bulgaria the clock shows 21.18.
Regards:
K.Vassev
hi. please switch to using email.
dreben
Post by dreben »
Hi Dave, after the last update everything is fine. Thanks a lot. My best regards:
Krassi Vassev
