b35 will not run
b35 will not run
Downloaded, tried both from kJams and from the site.
Gave it full disc access, i wasn't allowed first.
Put it in App. folder (tried Desktop too)
it hangs on launch.
Log:
0:
-------------------- New kJams Log --------------------
0: Reticulating Splines
0: kJams 2 2.1b35 (64 bit)
0: Date/Time: 2021-06-01 20:02:57.172 +0200
0: Allocating MetaData Traits Database
0: Initializing eCommerce Engine
0: Validating “kJams 2”
0: Paddle: Validating: “kJams 2”: Did it work? Yes!
0: macOS 11.4 (20F71)
0: macOS System Vers: 0x00101600
0: Unknown, Cores: 8
0: Clock Speed: 2.0 GHz
0: Total RAM: 16 GB
0: Encoding: Western (Mac OS Roman)
0: Locale: en-SE
0: Locale ID: “en_SE”
0: Creating CFNetwork Event Handler
2: Entering Thread: <CNetHTTPClient_RunLoop>
0: Loading version tracker
0: Initting Object Tracker
0: Loading Plugins
0: Loaded: kJams Burning Plugin, v1.0f3
0: Validating “kJams Producer”
I email video.
Re: b35 will not run
b36 coming in about a half hour
It's ok to wait. But b36 not out yet, right?
... or am i looking at the wrong place?
b36 is out. get it at the same link.
Ok, it is still b35 under info. And still crash at launch. New dialog though.
Log:
0:
0: Date/Time: 2021-06-03 4:22:25.150 +0200
we know b35 has the bug, so no need to send me bug reports on THAT.
the problem is you're still running b35. It is fixed in b36. if you're still running b35, then something went wrong with downloading or running the correct version.
Ok, so another problem but still :)
I cleared cache and history
on
https://karaoke.kjams.com/wiki/Installi ... load_Links
I DL from the kJams 2 link
https://www.dropbox.com/s/l5k9b84333x0j ... 2.zip?dl=1
But just get b35
Trying Lite and Pro, both b35
Please advise
terribly sorry, my DropBox wasn't even RUNNING :( Of course my LOCAL copy showed the correct items, so i assume the mirror at the server has the same, of course, cuz that's what DropBox DOES for you, right? well, yes, but, only if DropBox is actually running... derp. well try it now.
Ah, been there, done that :-)
