Playlist by Disc
Braciata
Playlist by Disc
Post by Braciata »
Hello! I recently bought KJams Lite. I would like to filter my karaoke files using Disc ID to remove duplicatea. I would like to know if it is possible.
Thanks in advance.
Re: Playlist by Disc
you can sort by album, which i think gets you what you want?
Braciata
Post by Braciata »
Thanks for your reply...
Not really.. I will make an example of what I mean.
I have these two files that have the same disc id but different names.
CB20431-11 - McBride, Martina - Broken Wing, A
CB20431-11 - Martina McBride - Broken Wing, A
I wondered if the software can see it as double.
If I sort by album I have CB20431 only and it includes the whole cd.
KJams uses meta data to determine track identify, so there is no way to see those tracks as identical.
If you do a search for that artist thought, then sort by arist, you can batch fix those bad data fields.
Also, if the album is in one of the online databases, you can fix them an album at a time.
Braciata
Post by Braciata »
Thanks for your answer
what you want to do is reinterpret your meta data:
https://karaoke.kjams.com/wiki/Reinterpret
then get Perfect Metadata:
https://karaoke.kjams.com/wiki/Perfect_Metadata
then you can sort by whatever you want.
Braciata
Post by Braciata »
Yup!
This is what I am doing!
:D
