Kjams installed and running on Apple Time Capsule
karaokeniagara
Post by karaokeniagara »
So i was experimenting just the other day.
Open wifi on mac and choose time capsule wifi connection, same with ipad.
1) installed and activated kjams 2 on my macbook pro.
2) opened music folder and copied kjams folder.
3) pasted kjams folder in the time capsule and created alias (shortcut)
4) deleted kjams in music folder on macbook
5) copied alias from time capsule and pasted into macbook music folder and renamed alias to kjams
6) started kjams program and let it load.
7) imported my karaoke songs folder located on the time capsule.
8) let it reference songs using correct naming structure and let it save database.
9) wah la! Everything is running completely wireless. Macbook pro connected to bluetooth speakers, Airport time capsule just plugged into wall. iPad app wtkjams Ke also working like a charm.
Cheers to Dave for creating such a beatiful program.
Would be cool to create a simple browser based song requesting kiosk program to integrate with the server.
Re: Kjams installed and running on Apple Time Capsule
you mean like this?
