exporting to quicktime
garfield2344
Post by garfield2344 »
what would cause the program to freeze up when trying to export song to quicktime? It always worked and now it freezes up.
Re: exporting to quicktime
mac or windows?
what file format is the song?
are you changing the key or volume?
garfield2344
Mac, not changing key or volume. CDG
i'm not having any trouble. what is your QT export encoder and presets set to?
garfield2344
iPod
Defualt
Pad CDG Movie Border to 320 x 240 is Checked
Export .xml meta data is Checked
It's worked ever since I've had the program, about 3 years, and it just stopped one day.
I'm running 1.0.1b81
for some reason, "iPod / Default" is horribly slow on my computer, but it's not freezing. (edit: there's a bug where it exports at 2x normal size, and i had "High Quality CDG Upscale" turned on). Have you tried "MPEG-4 / H.264 Best" ? i think that should work. what is your MacOS version?
garfield2344
OS 10.6.8 It still freezes
I just tested it on 10.6.8 and it worked fine, so i'm at a loss to explain what's different about your specific machine.
you say "it always worked", so have you tried to downgrade to find out which version it stopped working in?
still waiting to hear back from you
garfield2344
No I haven't tried to downgrade, but I will
garfield2344
I put in an older version of Kjams but exporting to quicktime still locks up kjams
okay so that proves that it's not kJams that's at fault, it's something about your system.
I *did* just fix kJams to output the correct size, though i haven't made a release. If you'd like to test that, let me know, also tell me your platform (mac or windows) and what edition of kJams (Lite, Pro, 2).
