Song Management
djunod
Song Management
Post by djunod »
Is there a technique or software that you are using to keep your song library free of duplicates?
I have a song library for testing, but it has a ton of duplicates. Would like to get it cleaned up without a lot of hassles.
Re: Song Management
https://karaoke.kjams.com/wiki/Preset_Playlists
you have to have "Perfect Metadata" for that to work, however
