Cheers/clapping after each song end
An option to add a sound file of your choice that will immediately trigger after each performers song ends. For me this could contain cheers/clapping or a jingle. A thumbs up splash screen or a Thank You! would be great as well from you. This sort of thing fills that sometimes awkward gap perfectly & singers always like that support behind them in my experience
Kind Regards,
DJ MAX!
DJ MAX!
Re: Cheers/clapping after each song end
I wrote the following:
https://karaoke.kjams.com/wiki/Code/new ... cts_Player
You can add whatever FX you want. Lots of applause tracks are available online.
I found a great program to play sounds for free… Version 2 is free to use. Version 3 costs 100 bucks..
http://figure53.com/qlab/
Actually i downloaded version 3 and that seems to work for free as well… Love it!!!
