Using parents' mac-mini I just need to burn cd-g's
adamnG
Post by adamnG »
Hi there,
I'm not that well versed in computerdom and wanted to find a program to burn cd-g's to discs that i would download from buykaraokedownloads.com. I don't use my PC at home for internet stuff but my folks have 2 Mac-minis running 10.4.9. I assume that since most burners don't burn CD-G's that the one built into a Mac Mini (MATSHITA CD-RW CW-8124) wouldn't either. I'm not much of a troubleshooter. Any advice for a newbie?
Thanks,
Adam
adamnG
Re: Idiot using parents' mac-mini just needs to burn cd-g's
Post by adamnG »
just saw an old thread recommending an external Plextor drive for Mac Mini. any technological advances been made since then? glad you're doing this, by the way!!!!
ChurchCat
Post by ChurchCat »
There is a page on the Wiki that gives some advice
http://www.kjams.com/wiki/Compatible_Drives
You can use an internal drive and an adaptor, this seems to be the cheapest way. External drives are hard to find. You may find some old stock on the internet.
The situation is very hit and miss. Not helped by the speed that manufactures change their models. Best to double check any drive by an Email to tech support before you buy.
At some point I intend to have a really good search to find current models that work for sure, I just need to find an idle hour or two.
CC
Yep, you'll need to get an external drive, i know it's a hassle, but them's the breaks! -dave
btw: you are not an idiot :) that was a perfectly legitimate question!
junior120872
Mac Mini Combo drive
Post by junior120872 »
I've been hoping to get the Matsushita drive in the mini working. I've got Windows Xp on the machine as well and have successfully burned a CD+G CD with Power CD+G from PowerKaraoke. I'm hoping that the Kjams Burner plugin will have it going soon, so I can remove windows from my mini. Anyone have any insight?
please put a CDG in and run kJams then send me the log file. ths will tell me some important info about your CD drive
junior120872
Mini.
Okay. I'll work on it tonight, and post the log within a couple hours. I can see if I have any type of logging from the windows app as well and post it.
okay
all i need is the bit at the very end, telling of drive capabilities.
i don't need anything from the windows log, that won't help me.
by the way, even if i am able to determine that it is possible to burn on that drive, it will be a very long time until i'm able to write it.
junior120872
That's fine. I can still continue the burning process in my Windows partition. I love the product, and I've purchased both the plugin and the lite version of Kjams, so I'll be ready when you are.
Thanks,
I'll post the end of the log as soon as I can.
Ivan
junior120872
Dave,
Did you get the log I sent over last night?
I
it seems to me that the disc was not IN the drive when you sent the log file. that's the critical part. like i said:
run kjams
put any CD in the drive
send the log file
that's it
junior120872
I just sent you the correct log file to your email address.
Thanks,
Ivan
according to your log:
Device does NOT support CD+G
Device does NOT support Deinterleaving
Device supports DVD-ROM
Device supports CD-RW
Device supports CD-ROM
Your drive is not claiming to be fully capable of reading CD+G. That means you *may* get some, some times, but it is not guaranteed. kJams at this time can only support drives that has support for CD+G in hardware, sorry.
junior120872
Thanks for all your help in this. I'll just continue to burn in Windows in the event support changes. I also have a supported external drive that I may plug into the mini to dedicate for Kjams. At least at that point I'll be able to use the plugin.
Thanks again!
Ivan
