Duplicate Files Deleter
Re: Duplicate Files Deleter
1: don't add duplicates to kjams (if you add the same folder twice, by reference, then you've just created duplicates)
2: get perfect meta data
3: create a preset playlist of dupes (strict)
4: select all in that preset playlist
5: Edit->Trash Original Files
or: can you explain more clearly what you mean?
