I just bought the lite version and installed the plugin for buring (no paid its on the 2 limit).
I made a playlist with tunes I bought from one of the retailers built in. The burn icon looks like it is closed (all gray). I click it anyways to see what it does and I get an error that they audio and video sizes were different.
I have checked the drive and I can burn items directly from the OS. It is also one off your approve list.
Any ideas?
Burning issues.
Re: Burning issues.
clear your cache (audio prefs) and try again.
or: you can only burn MP3+CDG files. show the "format" sort column, it should say "mp3", not "m4v" or something else.
Re: Burning issues.
Clearing the cache worked for the write issue. It looks it burt it to music only tho. I looked at the wiki but still dont understand how to get CD-G.
Re: Burning issues.
AIFF-C audio is the file type it saved as.
Re: Burning issues.
Sorry, I think I got it now. The originals are .mov files. I need to download the correct sources I think.
Thanks for the assistance.
Re: Burning issues.
the built in music stores ONLY sell MP3+G files (some ALSO come with m4v files), so i don't know how it's even possible you've got into this situation?
Re: Burning issues.
"StewarD"
Re: Burning issues.
if it burned only music then you are probably NOT burning a CD+G track. If you burn any NON CD+G track, you get only music. you "get" CD+G tracks by ripping CD+G discs or by buying them from a built in music store (or elsewhere).
