Video Out?
way2fst4u
Video Out?
Post by way2fst4u »
how do I get video out?
Scott
Re: Video Out?
check the FAQ
way2fst4u
Re: Video Out?
Post by way2fst4u »
I wish you wouldn't have moved this. In context: If I do a Thunderbolt drive, how am I supposed to get Video out, considering I use the Thunderbolt PORT for VIDEO OUT...
Scott
Re: Video Out?
sorry, seemed like a completely new topic to me. but i see your point, it IS related to using a TB drive.
many ThunderBolt peripherals have a daisy-chain port on them. you would eg: plug the drive into the TB port on the computer, then the display into the *second* TB port on the drive.
way2fst4u
Re: Video Out?
Post by way2fst4u »
dave wrote:sorry, seemed like a completely new topic to me. but i see your point, it IS related to using a TB drive.
AHA...I did not know that. I will look into making sure the drive has that capability since they don't make TB hubs yet...
I have one more question, but It needs its own thread. Thanks Dave.
Scott
Re: Video Out?
