Midi mappable controls & auto cue next singer
Sgwhite
Post by Sgwhite »
Just purchased Kjams pro and I am very impressed with it so far but i would like a couple of features added if at all possible.
First being able to map the start, stop, pause and cue buttons to a midi control.
Another thing that i noticed is that i was unable to find any option to auto cue the next singer after the previous singers song ends. This is a must have for me due to having to call out the next singers and usually having to wait for them to be ready.
Only other thing, is it possible to create custom video display so I can advertise my company name instead of the standard kjams logo screen.
Thanks in advance for any feedback on these matters.
Re: Midi mappable controls & auto cue next singer
Dave will need to respond for the midi bit but, if your on a mac ( some of this might work on windows but I don't know for sure)
I have crossover running
I have pause between tracks ticked in prefs.
Then when a singers finished their track (track 1) I hit the ⇾ button and the next track (track 2) is automatically cued up and whist I'm getting the next singer up iTunes is playing. When the singer arrives I hit the space bar, kJams plays and iTunes stops. (Beware, Make sure the play bar isn't at the and when you hit the ⇾ otherwise track 4 will be ready to play and not track 3
At least for 1.0, i won't be adding any MIDI controller, but the mac version DOES allow scripting via AppleScript.
so, use whatever MIDI controller software you DO have to issue applescript commands to kJams, and you're all set.
this is confusing to me because that's how kJams operates out of the box. when one singer is done, kJams automatically goes to the next singer's song. What are you seeing, exactly?
yes, but only on mac right now, see ShowScreens and kJams Producer
