alt/c
alt/c
Dave, Have you added alt/c as a shortcut to que a track up.
Re: alt/c
do you mean "auto cue" as in "move the playhead to the first audible portion of the song" ?
cuz the space bar will play the selected (or paused) song
Re: alt/c
Yep I do mean auto cue as in "move the playhead to the first audible portion of the song
I've always created a shortcut in kJams that does this and the shortcut I use is alt/c Then when a track is playing and a singer isn't ready to sing when the words start I can hit atl/c and the track plays from the beginning of the music
The reason I'm asking is I've just had a new Mini Mac (the drive of which incidentally reads CDG's) The reason I got it is because I can put 8GB of RAM in it. When I downloaded kJams the shortcut was there. There is more to the tale but I don't wanna bore you
Re: alt/c
oh! right! yes i did add that. :)
Re: alt/c
Oh you're a star. I use this shortcut more than any other
Re: alt/c
Re: alt/c
Not on the mac side.
Re: alt/c
It is on the Mac, thats the only computer I use
Re: alt/c
Well, I both tried Option-c (which did nothing) as well as looked at the menu, which had no key command after cue, so I am stumped.
r54.
Re: alt/c
if you have an old "keyboard.txt" file, you won't get the new one. if you chuck your file, you'll get the new one. but you'll lose any edits you previously made
