New update is off a bit?
mikekmikek
Post by mikekmikek »
I think the new update is causing the lyrics to be a line off (behind) from the audio files.
Re: New update is off a bit?
mac or windows
all songs or just some songs
check your slipping
garfield2344
Post by garfield2344 »
my friend is having the same problem with all his songs not lining up with lyrics since the last update. How can I help him?
please confirm "since the last update" by downgrading to the previous version and testing that.
if indeed it IS related to the latest update, we'll go from there.
otherwise, check your slipping.
garfield2344
What's the easiest way to downgrade to the previous update so I can see if that is the problem?
garfield2344
Never mind about the downgrade. I see how to do it. I will let my friend know and see if that helps his problem.
also, did you check your "Global Slipping"?
garfield2344
I will check the Globel Slipping. What should it be on?
it should be zero
garfield2344
Thanks that fixed the problem
