Can't Make software play karaoke songs
karaokefan
Post by karaokefan »
Hi,
I am evaluating the software and I have finally uploaded all my music and two things are happening...
1 - I have more than 15,000 songs via mp3 and the software is telling me that I need to upgrade ram.
2 - I can play a regular mp3 file, however the karaoke files will not play..
So, is the first problem related to the second? I read in the documentation that I may need more ram, which is not a problem, however I am puzzled by NOT being able to play the karaoke files. Do I need a plug in? I thought I read that somewhere but I am not sure. I do not need the burning plug in.
Thanks! So far the software looks awesome.
Re: Can't Make software play karaoke songs
i don't think "upload" means what you think it means. You either did "add to library" or "rip". "upload" means to push a file across the network.
http://karaoke.kjams.com/wiki/Glossary
then you need more RAM. any modern computer should have 4 GB or more of ram.
what "karaoke" files? what is the file format?
i don't exactly know what the second problem is, but i can tell you the answer to this question is unequivocally "no". Low RAM means searches will be slow, that's about it. It will still work just fine.
