On-line stores
djdave
On-line stores
Post by djdave »
Are there any other stores I can buy songs from, on-line, that will work as good as the 2 current ones?
For example, I need a copy of "Whipping post" by the Allman Bros. It's not available on Karaoke locker or Tricerisoft.
Thanks.
Re: On-line stores
if by "work as good" you mean "one click auto purchase/download/install/play" then no.
but if you mean "can i buy and download songs from the web" then yes.
http://karaoke.kjams.com/wiki/FAQ#Where ... ad_karaoke
this list is probably not exhaustive.
djdave
Re: On-line stores
Post by djdave »
Thank you:)
Re: On-line stores
