Highlighted words
garfield2344
Highlighted words
Post by garfield2344 »
Why is it that some song lyrics do not highlight at the rate the music is going?
Re: Highlighted words
when you say "rate" do you mean it gets progressively worse, or that they're all off by a fixed duration?
if the former, then perhaps the song was poorly encoded by the creator.
if the latter, you can fix it with Sync Slipping
garfield2344
Thanks Dave, I will try the sync-slipping.
