Playlist flexibility
franks
Post by franks »
Haven't seen this feature... maybe I missed it
It would sure be handy that after desired songs have been dumped into a play list or an additional song(s) has been added, that they can be rearranged or reordered in a more desired sequence.
Any comment?
Re: Playlist flexibility
Yes you can do this already, just drag and drop where you want the song or re arrange from the rotation screen.
franks
Post by franks »
Thanks for the tip Brendan!.... works OK
yeah, to do this you must be sorted by User Sort Order
