database error
big al
database error
Post by big al »
My kJams crashed during use and when i tried to restart the program it gave an error -
"This database was saved with a newer kJams, which writes database format (144.18603),
which is, unfortunately, greater what this version can read (1.10). You must upgrade to a later version."
I am using the latest version of kJams as i update it automatically when it is available.
I did try downloading the latest version from the website, but the problem persisted.
Please help.
Allan.
Re: database error
bummer, your database got hosed.
i hope you have a backup of your "kJams Library" folder, you must restore to your backup.
big al
Re: database error
Post by big al »
nope, dont have a backup of the kJams library folder. :(
i dont mind having to import everything back into kJams.
will deleting the kjams library folder get rid of the error and let me open up kJams and re-import my files?
Allan
Re: database error
yes.
note: not the "kJams" folder, just the "kJams Library" folder
