Choice of where to let rip
When I rip a disk it gets ripped the the music folders that are named by the artist. Is there a way to be asked where the disc is to be ripped to and then be given the option to choose weather we want the disc to be ripped to one place like a folder of our choosing thats called something like the disc identifying number.
I Change the kJams Music Folder Location in Prefs/ Advanced so that it looks a bit like this.
Image 1.tiff
Then I have to change the path back so Kjams can find the library when I reopen kJams.
Hope this makes sense.
Re: Choice of where to let rip
kjams was not designed to work that way. if you do work that way and run in to trouble (and i expect that you will), i can not help you.
you should set the KJMF and forget it, never change it.
OK. I'll leave well alone.
yeah what you want is to rip the music as usual, then *export* "original files" to whatever folder you want. if you want them to LIVE there, then delete the originals (from within kJams, Edit->trash original files), then add to library that new folder which lives wherever you put it.
