Thanks in advance. I just got my Macbook Pro and downloaded the trial Kjams pro. So far so good, just a few questions.
1.When I insert a disc, it opens I-Tunes, can I shut that off?
2.My built in drive is HL-DT-ST-DVDRW GS23N. It says it won't work, try anyway, and it appears to work fine, both with playback and 3 song burns to my hard drive.
Will this drive correct bad discs, and can I turn off the warning/try anyway message?
3.is one database better then any other?
4. How do I adjust the quality/bits per sec. of my rips. With external hard drives so cheap, i think the highest quality burns may be the way to go.
5. Does anyone recommend a specific laptop/mixer case/
Thanks again,
DJDave
Basic questions I didn't find an answer for
Re: Basic questions I didn't find an answer for
You're welcome, in advance.Thanks in advance.
http://karaoke.kjams.com/wiki/Ripping1.When I insert a disc, it opens I-Tunes, can I shut that off?
look under "details"
then you're all set!2.My built in drive is HL-DT-ST-DVDRW GS23N. It says it won't work, try anyway, and it appears to work fine
please understand the words you are using:both with playback and 3 song burns to my hard drive.
http://karaoke.kjams.com/wiki/Glossary
i think you mean "rip"?
in fact it will. it fixes "glitchy" graphics and creates more pristine discs. see:Will this drive correct bad discs
http://karaoke.kjams.com/wiki/Compare
just check the "don't warn me again" check boxand can I turn off the warning/try anyway message?
I presume you mean the online MetaData databases. KJPro™ is the best one. but first try the other three.3.is one database better then any other?
again: http://karaoke.kjams.com/wiki/Ripping under "details"4. How do I adjust the quality/bits per sec. of my rips.
MacBook Pro with utterly maxed ram. I got a Motu UltraLite and it rocks.5. Does anyone recommend a specific laptop/mixer case
Thanks for the quick response,and the heads-up on the Motu.
I was wondering about a protective case for my gear that offers a good workspace and ease of set-up and breakdown.
yep i don't know about that. someone else will have to chime in here?
I use cases from Gator, and a laptop stand from Stanton.
Gator cases:
http://www.gatorcases.com
Laptop Stand:
http://www.walmart.com/ip/Stanton-DJ-UB ... d/12169385
Gator cases:
Laptop Stand:
Sedge
Sedge
