CDG file types
franks
CDG file types
Post by franks »
Dave,
I can burn MP3+G(CDG + MP3) files as generated with kJams that will play on a compatible MP3+G karaoke player(or computer). But can you you enlighten me on how to produce a CDG+G that will play on a standard karaoke player that does not have MP3+G capability. Is this a special process or is it described somewhere in a tutorial? ... or I just don't understand ...... can really use steps #1, #2, #3... sequence to understand process.
thanks again
Re: CDG file types
you're thinking too hard.
just burn a disc with kJams, that's it.
http://karaoke.kjams.com/wiki/Burning
franks
Re: CDG file types
Post by franks »
Dave....took your suggestion and just burned from a playlist. Played back on standard karaoke machine but only audio played. I guess I need an external CD+G burner... correct? Am now using the duo cored Intel processor with Pioneer DVD-RW-DVR-K06.
Re: CDG file types
if you burned the disc with kJams, using the burning plugin, then yes, your drive is not compatible and you'll need a real CD+G drive
you should get a plextor
http://karaoke.kjams.com/wiki/Compatible_Drives
