Unable to select from existing singers
scottinhawaii
Post by scottinhawaii »
Hi Dave,
I'm not sure whether this is a feature request, a bug, or intentional??? We have been using kJams since it was kTunes and have venues and singers with lists of favorites and attached pitch changes. When I open iJams and select the Venue, none of the existing singers are listed to select from. I can, however, create new singers and use the software well. Once I get to this point, it's great. I know the software is working. I can understand that you would not want a user to be able to manipulate someone else's playlist, hence the password, but will I need to create new singers from an iPhone and copy the existing playlists to the singers for each of the individuals who wants to use iJams? Is there a way to add the password in kJams, or make the singer visible to iJams?
Thank you,
Scott
Re: Unable to select from existing singers
you must set a password for each pre-existing singer that you want available to iJams
to set a password on a singer, right click them and go "Get Info", then set a password.
Dave and I hashed this one out a few nights ago. I think we decided to change the popup to include all singers in a current venue, with singers with passwords highlighted somehow.
Assuming he remembers the convo ;).
the other day i was....
no, wait.... that wasn't me.
Was too!
wait! where am I? who am I? *WHY* am I?
For some reason this popped up as an e-mail alert just now (almost five years later). Since it came up, I might ask, any chance to get the list that populates the pop up on the server page ordered with Singers marked as Here at the top of the list, prior to the alphabetized list?
isn't that list actually sorted by the client?
yes, it's entirely possible
let's talk via email
