Smoother playback of full-motion video
El Ramos
Post by El Ramos »
First, great work on kJams, Dave! I'm grateful for a Mac-based karaoke solution.
I've encoded a few of my own full-motion, full resolution karaoke videos from laserdisc for use in kJams. Problem is, the video playback is pretty choppy, even when the rest of the interface is idle. Playback in QuickTime Player is 100% smooth though, so I'm pretty sure my computer has sufficient horsepower (I'm on a MacBook.)
The files are 640x480 MP4-encoded video with MP3-encoded audio. Total data rate is 4Mb/sec. (about 3/4ths the data rate of a DVD). Everything's wrapped in an AVI container.
Here's a screengrab:
Any chance these could play back at the full 29.97 frames per second in kJams? I'd love to reproduce the original "video" look of a laserdisc!
Re: Smoother playback of full-motion video
have you turned on "use coregraphics"? it won't get "smooth as glass" but it should improve playback performance.
i will be rewriting the whole quicktime engine using QTKit before 1.0 ships, with that you can expect "smooth as glass" performance even at high framerate on a very large monitor.
El Ramos
Post by El Ramos »
dave wrote:have you turned on "use coregraphics"? it won't get "smooth as glass" but it should improve playback performance.
Turned it on now and do see a performance improvement, thanks. Scaling is smoother, too.
dave wrote:i will be rewriting the whole quicktime engine using QTKit before 1.0 ships, with that you can expect "smooth as glass" performance even at high framerate on a very large monitor.
To quote Dave: 8)
