KTP to kJams graphic "over writes"
franks
Post by franks »
Dave,
Am including 3 screen samples of what I refer to as graphic "step ons" or "over writes".
This happens when I open Producer and see the resulting CDG video screen as converted from "Tuneprompter".
The 1st word in a sentence is almost always "over written" by the succeeding word graphics.
Although this can be manually fixed on a word by word basis, It is time consuming.
I don't know if I have a wrong setting somewhere that causes this since you mentioned you have not encountered this problem.
Also am including the original KTP file.
sample #1.tiff
sample #3.tiff
sample #2.tiff
Re: KTP to kJams graphic "over writes"
what those pix show are the result of a bug from an old version. in producer, option click the timecode button and it will self correct
you will lose all changed you made in producer (if any) and the file will revert to what is in the KTP file
