Label sorting
Label sorting
I use the Label heading to colour code some tracks and when I've done I turn it off. Whilst it it turned on If I click the label column to sort, kjams freezes so I forced shut down and then kJams crashes on opening. I managed to get over the problem by using a time machine backup.
I would like to sort via the label column from time to time but after that experience I won't until it's fixed.
Will I have to wait till you invoke mySQL.
Re: Label sorting
i am able to sort by label just fine, no problem at all. do you crash on the latest version? send the crash report.
also: zip and send your "kJams Library" folder
Re: Label sorting
I've not tried it on the latest version and I'm a bit worried about trying it again. I'll make sure I've got everything backed up and try it
Before I do it did you close kJams and reopen it with the Label column is visible.
Re: Label sorting
yes i did that
do not worry about crashing, you will not lose data just because you crashed
Re: Label sorting
Done that
I've sent the crash report vie email
kJams won't re-open The progress window gets stuck on Sorting by "Label" After 2 mins of trying it gives up and I get a crash report
I'll send the crash report from kJams trying to open
Re: Label sorting
i'm working on it, new release tonight
Re: Label sorting
Thanks for sorting this out Dave, Your a star.
I can now colour code my tracks with confidence and sort them. What a guy
Re: Label sorting
if any others are having this trouble, i did not actually release this fix, i sent a test version to Karanight. the next release will possibly happen thursday if it can be justified. If you have this issue, email me directly and i'll get you the test version right away.
