fixing mic lag, or delay
ylwoods
Post by ylwoods »
Hi,
I'm new to this karaoke from a Mac. Everything is working fine, BUT.... There is a delay between actually speaking into the mic and it coming out of the speaker. Is there a way to "close the gap" on this? Is this what "Sync-Slipping" is for? (It doesn't seem to make a difference.
I am using a usb mic through iMic on a MacBook Pro.
Thanks,
Steve
Re: fixing mic lag, or delay
I use a mini mixer by Behringer, this eliminates any delay and gives you echo and two inputs/ volume controls for your mics. I think you can buy the mixer for $35 online. I'm not sure what others are doing.
mikefala
Post by mikefala »
Hi Dave, when you added the Microphone capability and level control slider to kjams you said there would be lots of delay and there was/is. Are you working on an update to address the issue of delay? I hoped that when I upgraded to a new macbook pro 3.06 and 7200 rpm drive running 10.6.2 and 4 gigs memory that the delay might be lessened but it hasn't; any thoughts?
Mike
By dave » Fri Dec 04, 2009 8:08 pm
yes i know, it's on my list to fix, i definitely will be fixing this.
meanwhile, use AudioHijack or LineIn or GarageBand
http://karaoke.kjams.com/wiki/Microphone
same status as before. it's pretty low priority compared to crashing bugs and new features, considering there are half a dozen ways around it, including a couple free alternatives.
New Features? Wait, what?
I wanna ma icon workin'! :)
now you're just being silly.
In a world without walls and fences, who needs Windows and Gates
okay people, back to work. move along. these aren't the droids you're looking for.
