Download to trash
Download to trash
I don't know if this is a bug or the way my prefs are set but the last two time I've checked on update and clicked to update, When the updates finished kjams hasn't opened automaticly and when I've gone to open it, kjams has been in the trash, which is the last place I'd put an app like kJams.
I've then gone to the web site to download with no problems
Re: Download to trash
are you *sure* the one in the trash is the NEW version and not the OLD version?
Actually your correct, it's the old one in the trash but the new one doesn't get downloaded so I go to the web site.
perhaps you have a permissions problem. try "repair permissions", then see if the next update "just works".
also: is your kJams app in your Applications folder? and are you an administrator?
I've done the "repair permissions" and also for some reason kJams was in the download folder and not in app's. I've now put it in app's so hopefully the problem will be solved. Thanks
:D
