how to put repaired meta data on songs back into library
leslie&co
Post by leslie&co »
I have kjpro and am setting up my library. I am using the data bases to repair bad meta data, this works well but once repaired how do i get the info back into the main library.
Also many of my songs titles and artist came in with a -before the name, is there a global fix? I have collected thousands of songs over the years.
Bill
Re: how to put repaired meta data on songs back into library
do you mean you're fixing your file names outside of kJams? please specify your exact workflow.
and yes, there is a way to remove the dashes. but i need to know exactly what you're doing first.
