Fade Out As A Template
drumkey87
Post by drumkey87 »
Is there any possible way you could create a Fade Out and save it as a template? I'd like to make a fade out as my outro template, would save me so much time so I wouldn't have to apply a fade out at the end of every song. I tried to do this but it didn't seem to work :-(
Re: Fade Out As A Template
I think you're not getting how it works. In order to create a fade, you must specify the duration of your fade using the time selection brackets. a template does not require that. a template places objects in to your scene: text and/or graphics. a "fade" is neither of those things, it can not be represented by a template.
