First you must correctly enter all your "1-click settings"
Fairyoke
Post by Fairyoke »
This is new to me. Sorry if it has already been addressed. I just attempted to purchase some music from Karaoke Locker and I got this message. I have now tried every possible configuration of the 'store' settings: nadda. TriceraSoft seems to work as always.
Re: First you must correctly enter all your "1-click settings"
did you enter a phone number?
Fairyoke
Post by Fairyoke »
I haven't entered any new information. Is that a new field? Let me check...
Well, that did fix the problem. Thanks again.
aisthesis
Post by aisthesis »
I'm just trying to get started with the software and am having exactly the same issue. I have entered my phone number, but it doesn't seem to be saving my credit card info.
please describe the sequence of events, if you don't, i have to guess what you're talking about.
eg:
run kjams
open prefs
click "stores"
click "edit credit card info"
enter info
click ok
--> all the info is gone!!
is that what you mean?
