I tried to export a track as Quicktime from the library and I got a message saying "There was an error encoding the song "Don't be Stupid.m4v":"afpAccessDenied, Insufficient access privileges for operation"
I then tried to do the same but using the actual disc and I got the same message
The disc was ET028. I've done this several times successfully and after I had the problem I went on to export another track as Quicktime with no problems. Is there some reason that I can't do the export with a ET disc
Not allowed to export to Quicktime
Re: Not allowed to export to Quicktime
you have an access privileges problem, which has nothing to do with the song or the disc. you should do "repair permissions" on your disk. if it still happens after that let me know and i'll have a look.
Thanks for that, Fixed it.
