Audio Volume
toddsheets
Audio Volume
Post by toddsheets »
I downloaded and installed the last two versions of KJams and I am not sure which one facilitated this issue. However, over the past several days the volume coming for KJams is about 50% quieter than before. I tested the sound of my laptop with all of the other programs I use that output sound and KJams is the only one that is having this issue.
Does anyone have a clue as to why this is happening?
Any help would be appreciated.
Re: Audio Volume
turn up the volume knob :)
toddsheets
Re: Audio Volume
That was a hilarious but unhelpful reply. Thanks for the laugh though.
Re: Audio Volume
I've got the latest version and I played the same track on iTunes and kJams and kJams was louder than iTunes. Kjams has always been louder. If you've got a gig turn the volume on kJams all the way up and turn the volume on the other apps down to suit and leave then set like that throughout the gig. I find if I've had the kJams volume turned down for some reason I've still got plenty of volume control with my amp. You could try re-downloading kJams or downloading an older version till the problems sorted.
Re: Audio Volume
well i have never heard of this happening i really need to see it in action to diagnose the problem, please make an appointment.
