able to search for songs,add songs easer from other external
TAZ
Post by TAZ »
it would be nice to search and add songs (multiple) from other drives such as in iTunes.
Thanks.
j.
Re: able to search for songs,add songs easer from other external
what? iTunes has no ability to search hard drives. just like kJams, you must add the files to the library to search them.
kJams can work with however many drives you want, it leaves the files in place when you add them, and will search them. so i really don't know what you mean.
Sedge
Post by Sedge »
I bet he means having the option to copy the files into the kJams music folder.
We've certainly been down this discussion before, and I think it's on the list somewhere.
>>Sedge
OIC, yes, obviously TAZ, i will be adding that. not very high priority, you understand, since there is a workaround (drag and drop the files to your internal drive first)
