Starting song ID
dschallock
Starting song ID
Post by dschallock »
Hello,
I sent this basic question to the author but thought I would ask here in case some one knows on the board.
Thanks ahead of time for any help.
My Name is Dan Schallock and I am trying out Kjams Pro. I am very impressed.
One thing I am trying to do is re-import my songs into my library after deleting the library.
I was trying to re-import them in the same order I imported them the first time so that the songs will have the same "Song ID #".
They seem to come in this 2nd time with higher starting number. (First time the starting number was 32371 and the second time it was 32836).
Is there any way I can tell Kjams to start the SONG ID # the same as the first time when re-importing?
The reason I ask is, I have already invested in printing song lists.
Thanks,
Dan
Re: Starting song ID
the answer is that you can't assign song ID's
the database creates the song ID, there is no way to change it. if you've invested in printing a song book, then you can NOT rebuild your library, or all your IDs will change.
that's why i say: stop using song IDs! just use the song name + album name instead.
