Template Not Showing Up
drumkey87
Post by drumkey87 »
I've been importing tracks into Kjam from TunePrompter and opening them in the Producer Plugin and usually they will have a template at the beginning that says created with kjam and has all this other info title, time, etc. But for some reason this particular karaoke track I imported does not show a template at the beginning. I've tried to create my own template with a title at the beginning but it won't let me
Re: Template Not Showing Up
you can just open it in producer and insert the template manually, IF THERE IS ROOM. If there is not enough room for the template to be inserted, it won't insert. (that's what the silence at the start of the song is for).
you can make a shorter duration intro template by removing the graphic and the "kjams producer" logo if you want.
