This is something I've thought of asking for a long time
When singers come they all expect you to know there name, even though I might have only met them once. I can often remember the songs they've sung but not their name and it's a case of " can you put my songs on" and then their gone. I'm usually too busy to run after them so I go through the singers list to try to remember their name. If there was a way to search particular songs within the singers files without opening them it would help. It would also help when I do know their name but I've got 6 singers with the name Dave, I normally need to open three or four files to find the singer in question
Another way could be to be able to put a photo of them on their file but I think that would take up too much room.
I always try to tag little reminders onto the names of singers but it isn't always suitable.
Search song in singers list
Re: Search song in singers list
been planning on allowing you to take photos since the beginning.
i'll add your request to the list but, seeing as it's pretty specialized and only ever requested once, it's pretty low on the list.
I thought as much as nobody joined in, I can't grumble though cos the features you're putting are top class
well, photos will get in there eventually
