Select from multiple hard drives with different names/songs
tidied
Post by tidied »
It would be great if when KJams opens, it askes which library you want to use...I use multiple drives and depending on which one I have for the night, I have to have everything loaded in to 1 library...Just a suggestion,
thanks
yeah
at this time kJams is designed to run with one library. this sounds like a 2.0 feature
